Archived
Get rid of all config files. Engine resource file.
Related products:FME Flow
fmelizard
Migration Note: Idea originally posted on 2015-10-29
rylanatsafe
Forum|alt.badge.img+13
We have made some improvements to the FME Desktop product since this comment was posted. If there are still some more features you would like to see, above what we have available in FME 2019.0, please create a new idea posting!
jhawks
Forum|alt.badge.img+7
  • April 22, 2024
More specifically...During Server install there's no gui to point to an external database (to house the repositories etc). If you want that option after the install is done you have to go edit fmecommonconfig.txt and bounce the service. Id much rather gui asking "What external db do you use? oracle, postgresql, sql server? And then take you the appropriate gui for which ever one you selected.
sigtill
Forum|alt.badge.img+24
  • April 22, 2024
Get access to FME_SHAREDRESOURCES from FME Desktop
rylanatsafe
To help us out with this idea, please let us know what configurations are the most important to you! There are many different config files and parameters set within, and we are unlikely to do a single sweep of everything – and will more likely tackle one piece at a time.If you are able to share what parameters you edit in the config file most often, it will help us prioritize the focus. For example, I suspect editing database credentials is more popular than changing the "maintenance idle wait time" for an FME Engine.We have our configuration files in documentation.
