Open
Use attribute value in RandomPointGenerator
Related products:FME Form
jonas_nelson
There is a custom transformer named RandomPointGenerator which can generate random points in polygons. However, it can only use the same single integer value for all polygons. If the possibility would exist to create N number of random points, where N is an attribute value different for each polygon, this transformer would be much improved.
jochgem
Forum|alt.badge.img+4
  • March 29, 2024
I totally agree. Moreover, if you could specifiy what needs to be randomized, such as an integer, location, string value, etc. it would create even more benefits for the community.
jochgem
  • March 29, 2024
Hi Jonas,
See the post below that is in part answering your problem:
