If a query in SQLCreator does not return any records it is not possible to terminate the workspace because there is no output.
In SQLExecutor there is an output port 'Initiator' with the number of records in '_matched_records' which can be tested.
Is it possible to add an 'initiator' output port in SQLCreator to make it more usefull,
