This is a minor user experience request. I want to see full version number in the window title and startup screen. Recently, I was using FME Workbench 2022.2.24 yet, both the window title and startup screen only showed a partial version number, "FME Workbench 2022.2." Since I had both 2022.2 and 2022.2.24 installed, this was confusing. I checked FME Form 2023.0.1 and see that it has the same behavior; it only displays "2023.0" in the window title and startup screen.
This should be easy to implement and it can only help users. I suspect that the reason the full version number is not displayed is merely because FME has always done it that way. Thank you for your consideration.
