Released
Dynamic attribute ranges/attribute classifier
Related products:Integrations
  • June 12, 2023
  • 35 views
chriswilson
I've been asked to help classify some numeric data and I wondered about the possibility of FME having a dynamic attribute classifier of some sort to group data into ranges with no user-defined values. Like a natural breaks or even manual classification in ArcGIS where in the latter case you might define a number of breaks or ranges but again without giving actual data values.
I know the AttributeRange Mapper has the ability to generate ranges based on specified max and min values, but you have to establish them first. This idea is around having FME do that on the fly.
Thinking it can be a quick way to analyse and understand data without having to play around with it too much or manually get there in desktop GIS.
LizAtSafe
Forum|alt.badge.img+16
  • June 15, 2024
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/Transformers/classifier.htm
