Often workspaces can't be run because the FME author created a new repository but forgot to "Share" as the last of the publishing process (step1-6 is FME form/desktop and step 7 is only possible in FME server/flow).
So I'm asking for a popup/reminder to FME admin that a repository has 0 user(s) and 0 roles(s).
What would be even better would be to set a default permission set. For example when adding a new repository, ask the user if they want to set recommended defaults of
- fmeadmin role has "Full Access" by default
- fmeauthor role = "Can Download" and
- fmeuser "Can Run"
