In Development
published parameters choice from query sql
Related products:FME Form
  • December 15, 2020
  • 13 views
DanAtSafe
  • DanAtSafe
    DanAtSafe
giosp
Please add the possibility to populate the "choice type" parameter with a fme reader. The fme reader is loaded each time when the workspace run. With this feature, it's possbile to have the parameter list updated before every execution.
andrewbnz
  • July 13, 2022
Yes please, this is an odd limitation in user parameters - I can import values into a choice list using SQL (or other formats) during the design of a workspace, but it's a one-off import and never refreshes the choices list whenever the workspace is run in FME or as a Server App.
Our use case is in particular is for FME Server Apps, in particular - we're trying to create tools to automate processes with FME, and a number of these would require selecting values in choice parameters, from databases which change frequently so having to update the workspace manually is a real nuisance.
