Archived
FME Data Inspector: Add Hidden Attributes to the Table View
Related products:FME Form
stipica.pavicic
Participant
To make data inspecting easier sometimes will help to have some of the hidden attributes available in the Table View.
Exposing attributes inside the FME Workbench is great but it will be also good to have the same option inside FME Data Inspector; to avoid reprocessing. That is very useful when working with a large dataset with many attributes. I've experienced a need for this while working with BIM/IFC files.
Attributes inside Table View can be used for data filtering and that helps a lot while inspecting some dataset.
Expose attribute/s functionality inside FME Data inspector can be, for example, implemented as an context menu that opens on the right click while selecting one or more hidden attributes from the Feature Information Window.
jdh
Forum|alt.badge.img+34
  • August 5, 2021
You can add the hidden attributes to the table view in the inspector. You just click on the Columns button and then select which ones you wish to display.
stipica.pavicic
Participant
Thanks @jdh, I wasn't aware of that... obviously :)
