Open
New Reader/Writer: AutoDesk Inventor Files
Related products:Integrations
erik_jan
AutoDesk Inventor is an industry Design tool, based on AutoCAD.
The files created by Inventor are not supported by FME (yet).
We have some customers that would like to use the data from Inventor files in other applications.
If you are using AutoDesk Inventor and want to be able to exchange this data to other applications, please support this idea.
Hello FMEers - I'm back. I am also looking at AutoDesk Inventor translations. And happy to be a tester.
erik_jan
Forum|alt.badge.img+21
  • May 19, 2017
Hi @lawrieturner. If you have the same requirements, please vote for this idea to get it higher on the priority list.
fmelizard
Forum|alt.badge.img+20
  • November 10, 2017
We're seeing more requirements for this format in the manufacturing space, where the format is used both for product design to load into cutting / grinding machines, robots, and for plant equipment and racking layouts. In order to estimate location-determination sensor networks, it is more useful to have the 3D view of things than just the floor-plan or plant layout.
sigtill
Forum|alt.badge.img+25
  • September 25, 2020
+1 for this. Helps to extract data from Autodesk Inventor. You can also use STEP-files. But that is not supported either.
gaplin
Participant
  • Participant
  • January 9, 2023
+1 we use Inventor for substation design and some other 3d work. Ability to read and write to pdf &/or pdf/a would be useful.
