Open
Universal Connection Support in FME Flow: Email Templates
Related products:FME Flow
jdh
In FME Server 2019 on the email subscriptions protocol settings there is a drop down Load Template menu to populate some of the settings as per popular email services.
It would be nice if we could add a custom template to that list, to use when setting up new subscriptions, rather than having to duplicate an existing subscription.
jdh
Forum|alt.badge.img+36
  • July 23, 2019
Alternatively, there could be an option to 'Use System Configuration' or by default the fields will be autopopulated with the values from the system email configuration.
denniswilhelm
Forum|alt.badge.img+17
Importing the configuration would be awesome. Right now you have to configure the same settings for each subscription which is a bit annoying.
I think defaulting to the system configuration if no other settings were made could also be an option.
jdh
  • January 28, 2020
And my IT department just retired it's email server, I now have to reconfigure 42 subscriptions. I was able to do it via the rest api, but I would have been a lot happier to change it in one place and have all the subscriptions updated automatically.
I second jdh suggestion to 'Use System Configuration' or have the fields autopopulate with that, but would add that if I need to change the System Configuration, there should be an option or popup when changing those values to allow me to choose to auto update all Automations/Subscriptions that use the values that are being changed.
I would also add that I would like to see similar Templates implemented for the "Make an HTTP Request" External Action as well. We have been using that to call the Microsoft Teams Incoming Webhook connector to post errors to a Teams channel as opposed to sending emails, which has worked well for us.
  • August 11, 2022
I like the idea having our email settings in a custom template.
Was good for subscriptions in 2019 and would be as well for automations today.
It's a bit annoying to copy our emails settings when creating an email tigger or an external action.
LizAtSafe
  • February 8, 2024
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
  • February 8, 2024
vxn43
Forum|alt.badge.img+18
  • February 24, 2024
Any update on if there are plans to allow users to create their own custom templates for use in Send an Email (External Action) in an Automation?
Would make all our lives easier not having to retype our organization’s credentials every time we add Email to an Automation,
LizAtSafe
  • October 10, 2024
OpenGathering Interest
LizAtSafe
  • October 10, 2024
LizAtSafe
  • December 3, 2024
LizAtSafe
  • April 5, 2025
LizAtSafe
  • April 5, 2025
LizAtSafe
  • May 30, 2025
Gathering InterestOpen
brandonguo
Forum|alt.badge.img+4
  • June 1, 2025
Hopefully user can change the template settings, and it will automatically apply to all automations that use this template. Sometimes our Exchange server will change and need update ip address of the email server, it really took lots of time to go through all automations and update it’s mail settings.
rylanatsafe
Forum|alt.badge.img+14
Thanks for your comment, ​@brandonguo —yes, that’s exactly the kind of experience we’re aiming for! Automatically updating all dependent automations when a template or connection setting changes would save significant time and reduce chance of error.
To provide an update on this idea: while email configurations are a common use case, we're exploring how to implement a more general solution that applies across all connection types—email, database, web, and more.
