The RasterBandInterpretationCoercer allows only for hardcoded choice or user parameter for all of its parameters like Destination Interpretation Type, and Conversion Options.
It would be nice if these value could be set by an attribute on the Raster. The Conversion options could also be simplified to Convert from Color, Convert from Numeric, Convert from Float to Integer, as the "to" interpretation is redundant when supplying the Destination Interpretation Type.
Any features with invalid combinations (like palettes restricted to UINT) could be output the Rejected port.
Archived
RasterBandInterpretationCoercer should support attributes for parameters
<strong>This post is closed to further activity.</strong><br />
It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br />
If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br />
