Open
Add a Transformer to Perform Iterative Operations for List Attributes - ListIter
Related products:Transformers
***Note from Migration:***
Original Title was: Add a Transformer to Perform Iterative Operations for List Attributes - ListIterator (tentative)
The expected transformer performs iterative operations for every element of specified lists, and then stores the result into new lists or overwrites source lists by the result. The user can declare aliases of source lists and define math or string expressions through the parameters dialog, like this.
The index surrounded by square brackets in the expressions indicates relative position of elements. i.e. [0] indicates every element, [<negative>] indicates a prior element, [<positive>] indicates a subsequent element. An editor similar to the Arithmetic or Text Editor can also be used to enter each expression. This transformer should support both simple list (e.g. _list{}) and complex (structured) list (e.g. _list{}.foo, _list{}.bar).
Example: If the source list and non-list attributes contain these values:
_list{}.foo = [1,2,3,4,5] _list{}.bar = [10,20,30,40,50] n = 1 prefix = 'P'
the destination list should be:
_list{}.a = [2,3,4,5,6] _list{}.b = [<null>,20,30,40,<null>] _list{}.c = [11,22,33,44,55] _list{}.d = ['001_S','002_S','003_S','004_S','005_S'] _list{}.e = ['P_101','P_202','P_303','P_404','P_505']
[Addition] It would be ideal if each expression could have "circular list" option. If the option is ON, the _list{}.b should be:
_list{}.b = [26.66666...,20,30,40,33.33333...]
Be the first to reply!
