Archived
Automatically import of the possible attribute values if chosen Attribute to Fil
Related products:Transformers
  • November 2, 2016
  • 0 views
nielsgerrits
hkingsbury
danilo_fme
birgit
liamfez
  • nielsgerrits
    nielsgerrits
  • hkingsbury
    hkingsbury
  • danilo_fme
    danilo_fme
  • birgit
    birgit
  • liamfez
    liamfez
***Note from Migration:***
Original Title was: Automatically import of the possible attribute values if chosen Attribute to Filter by has values for coded domains (for AttributeFilter)
taojunabc
Participant
  • Participant
  • November 4, 2016
Automatic import attribute value means that whenever you need to connect to the AttributeFilter, all the data scanned into the input data, If the data a lot, will have a large load on the PC. But, if a transformer connected to the AttributeFilter, All the steps needed to perform to this transformer so far to get the value for each attribute. So use AttributeFilter's import function is a good choice.
