Archived
Utilize FME For Telecommunication services (Network and data coverage )
Related products:FME Form
  • siennaatsafe
    siennaatsafe
  • najedjamal
I want to share with you one of my reference project that I did recently in middle east (Oman) for one of the telecommunication sector Called TRA - Telecommunications Regulatory Authority
The Telecommunications Regulatory Authority (TRA) was established in 2002, to liberalize and regulate the telecommunications services in the Sultanate of Oman.
In Oman there are two main operators (Omantel and Ooredoo) they provide telecommunication services and internet , the idea from the project to reflect the data collected by TRA on the map to show the internet coverage and call performance .
We used FME desktop and FME server , through FME desktop we build the workflow to process the data enter usefully the data updated every month , the input data is point data (Lat , Lon , ID , signal) our methodology used to calculate the majority values for the signals and pullulated as Hex with three different colors , To get more info you can use the below link :-
https://qos.tra.gov.om/loadMap;jsessionid=06CZAkQrS9_hgCQMjOsW5i4xcUv1GELwqsC58tIU.tra-qos-pro-ap0?locale=en
" target="_blank">https://fmecommunity-ideas.s3-us-west-2.amazonaws.com/untitled.png">
