Archived
Extending FME Desktop floating license to an AWS On demand/Spot Windows instance
Related products:FME Form
  • February 16, 2017
  • 11 views
***Note from Migration:***
Original Title was: Extending FME Desktop floating license to an AWS On demand/Spot Windows instance
I have a use-case of making use of FME services on an AWS instance especially with large GIS datasets (for ex: 20 million points) .
For this, my current practice is that after I boot up my AWS instance, I install FME Desktop version and then license it with a trial license code which comes with a validity of 30 days.
The problem I run into is,
With the termination of the AWS On-demand / Spot instance, I lose out on to the trial license,some times, within a day or two. So every time I boot up a new instance it also calls for a fresh license code.
I have tried the following but unsuccessfully.
- Create an AMI (image) of the instance before terminating it.
-Try to connect my FME floating license server with the Windows instance on AWS.
Can a provisioning be done to extend the valid FME floating license to the AWS Windows instance ?
Thanks
Forum|alt.badge.img+56
Just out of curiousity, have you tried FME Cloud?
srg
Forum|alt.badge.img+10
  • February 17, 2017
I know that Safe Software currently uses AWS for online instructor led training sessions, where the instance comes pre-loaded with the requisite version of FME Desktop, the training dataset and the manuals.
In a similar way it would be nice to have term licenses of FME Desktop on the cloud (AWS)
srg
  • February 17, 2017
I think the user is looking at using FME Desktop on the cloud to author workspaces
ryanatsafe
Forum|alt.badge.img+8
  • November 9, 2018
Running the FME Desktop floating license server on a nano EC2 instance would work.
https://knowledge.safe.com/articles/82230/create-fme-license-server.html
