Open
Api interface for FMEServer Automations
Related products:FME Flow
siennaatsafe
danilo_fme
nic_ran
radioactivetoy
+5
  • siennaatsafe
    siennaatsafe
  • danilo_fme
    danilo_fme
  • nic_ran
    nic_ran
  • radioactivetoy
    radioactivetoy
  • gwalrecht
  • namanpatel
  • keziaatsafe
    keziaatsafe
  • 3 Anonymous users
patrick_koning
To be able to fully automate the FMEserver it is nescecarry to be able to create the Automations by API methods.
The idea is to extract all sources and targets of all workspaces or a set of workspaces on the server.
Put them in the correct order of dependency and try to parallelize as much as possible.
So the FMEserver is used most efficiently.
If yoou think about cloud and effincient use of Fme engines this is the most optimal configuration.
Be the first to reply!
