Archived
Create a igds_info feature with Drawing System Variables like autocad_info but f
Related products:FME Form
gabriel_hirsch
***Note from Migration:***
Original Title was: Create a igds_info feature with Drawing System Variables like autocad_info but for Microstation V8 DGN-reader
The parameter Read Drawing System Variable in the AutoCAD DWG-readers are much used to retrieve information about a DWG-file. Currently there's no equivalent when reading Microstation DGN-files. This idea is for creating a new parameter in the DGN V8-reader: Read Drawing System Variable which creates an igds_info feature which holds information like DGN-version, units, current level an so on.
