In the Autodesk AutoCAD DWG/DXF reader you can choose to "Read Drawing System Variables" and a null feature of the type autocad_info is created. But there is no documentation of the attributes connected to the autocad_info feature.
As an AutoCAD user I can interpret the attributes but if you don't have AutoCAD it is pretty hard to know what is what. It would be better if there was a help section in the Autodesk AutoCAD DWG/DXF Reader/Writers documentation about the autocad_info feature and it's attributes. The current attributes that needs to be explained are the following: autocad_angbase, autocad_angdir, autocad_attmode,autocad_aunits, autocad_auprec, autocad_fillmode, autocad_insunits, autocad_latitude, autocad_longitude, autocad_lunits, autocad_luprec, autocad_projectname, autocad_proxygraphics, autocad_version
If I write this myself, will you include it in the help section?
Yes we will! But I'm sad to see this and will ask the team about it.
I have created a task for this, and it will be done shortly. Thank you for mentioning this.
Check out http://docs.safe.com/fme/2018.0/html/FME_Desktop_Documentation/FME_ReadersWriters/acad/Drawing-System-Variables.htm
This is very good news. Thank's alot! Safe Software rules!
