Archived
Add support for integrated Windows Authentication (IWA)/ Single Sign On (SSO) fo
Related products:FME Flow
siennaatsafe
danilo_fme
jdh
warrendev
chriswilson
+6
  • siennaatsafe
    siennaatsafe
  • danilo_fme
    danilo_fme
  • jdh
    jdh
  • warrendev
    warrendev
  • chriswilson
    chriswilson
  • tim_wood
    tim_wood
  • gbj1717
    gbj1717
  • borone
  • davidlee
    davidlee
  • markatsafe
  • DanAtSafe
    DanAtSafe
bjarne
***Note from Migration:***
Original Title was: Add support for integrated Windows Authentication (IWA)/ Single Sign On (SSO) for rest services (fmedatastreaming)
If you configure fmeserver for integrated Windows Authentication (IWA)/ Single Sign On (SSO), it affects the web UI only, not rest services (as far as I know). This enhancement will make it easier to access fmedatastreaming with published parameters etc. in a secure environment.
  • March 16, 2016
Hi
Why do I identify myself every time I use a service hosted by us internally.
Although I use AD integration to use FME .
Can someone give us instructions how to avoid irritation ?
Regards
Ahmed Jama
bjarne
Forum|alt.badge.img+5
  • July 27, 2016
some time ago we requested support for Windows Authentication (IWA)/ Single Sign On (SSO) for rest services (fmedatastreaming). Nothing happens... It seems to me that hardly anyone is interested in secure and userfriendly rest- services?How can we get some action?
bjarne
  • December 13, 2016
Is there any workaround for this problem?
bjarne
  • January 10, 2017
According to Safe support this feature is registered as Case-id: C120339
rylanatsafe
Forum|alt.badge.img+13
  • August 30, 2017
*The id number tracking this request is PR#58971.
bjarne
  • December 19, 2017
will PR#58971 be solved in fmeserver 2018?
sigtill
Forum|alt.badge.img+24
  • January 12, 2018
Is it possible that this will be fixed in FME Server 2018?
bjarne
  • February 11, 2019
Is it possible that this will be fixed in FME Server 2019?
rylanatsafe
Please note that this has not been addressed for FME Server 2018 or FME Server 2019. We do not have this work committed to our plans at this time.
So, what can you do right now? We would love to gather information on the various use-cases and workflows that you need this capability implemented for. What endpoints are you using? Have you integrated them into a custom web application? How do your users access the service(s) that ultimately trigger a Job on FME Server?
If you are able to provide a short paragraph and post it as a comment here, or, especially if you have drawings, diagrams, or screenshots to share (or confidential information) – please send them via Safe Support (remember to reference this Idea thread).
We will need to make an informed decision, and having this information in-hand will be critical if we need to evaluate different technologies to replace what we have currently – for example, what if we determine migrating our REST API to a solution with a better backbone that can support SSO requirements is needed; we want to make sure it best fits the mould of your workflow.
rylanatsafe
This has not been resolved for FME Server 2018. Please see my comment from 16 May 2019 in the main thread. (Posted for visibility in case other users come across this specific comment.)
rylanatsafe
This has not been resolved for FME Server 2019. Please see my comment from 16 May 2019 in the main thread. (Posted for visibility in case other users come across this specific comment.)
rylanatsafe
bjarne
  • February 21, 2024
one possible solution is to add functionality to configured a workspace to run immediately without showing the parameter form by adding a optional parameter ‘runImmedaiately=true’.
Example GET request: https://fme.flow.com/fmeserver/streaming/fmedatastreaming/repository/works.fmw?param=123&runImmedaiately=true
Steps:
1. The user cliks on a predefines url.
2. The user is authorized by Azure Active Directory or Windows Active Directory.
3. The output is prodused and returned to the user immediately.
