Released
Improve FME Server Installer with optional advanced Database Options for Distrib
Related products:FME Flow
siennaatsafe
virtualcitymatt
danilo_fme
warrendev
antoine
+2
  • siennaatsafe
    siennaatsafe
  • virtualcitymatt
    virtualcitymatt
  • danilo_fme
    danilo_fme
  • warrendev
    warrendev
  • antoine
    antoine
  • rudy_v
    rudy_v
  • steveatsafe
    steveatsafe
steveatsafe
***Note from Migration:***
Original Title was: Improve FME Server Installer with optional advanced Database Options for Distributed DB
With the increasing use of Distributed and Fault Tolerant Environments the installer lacks the ability to customize the FME Server System Database connection settings and provides only basic settings (host & port). In High Availability and Fault Tolerant environments these are typically not enough and users must edit config files to complete the connection settings. (in +2020.0 this is now two files).
The FME Server System Database can be stored in SQL Server, Oracle, & PostgreSQL. The drivers used are Java based and the installer provides hostname and port options.
The installer could be expanded to provide optional jdbc parameters much like the FME Workbench Database Connection dialog does when using the JDBC Reader/Writer format.
The SQL Server database is most often requiring this customization the JDBC Parameters. Some examples are:
serverName=<hostname>
databaseName=<databasename>
instanceName=<instancename>
portNumber=<#####>
MultisubnetFailover=true
integratedSecurity=true
It is proposed when performing a Distributed Database (or FT) install that adding a drop down to select the database type and provide options (check boxes) to include additional connection string parameters to add to the config file. (or type in manual parameters) would be helpful and reduce the need to edit config files after installation completes.
Related Ideas:
SQL Server and Dynamic Port Allocation https://community.safe.com/s/idea/0874Q000000TlFqQAK/detail
SQL Server and Windows Authentication https://community.safe.com/s/idea/0874Q000000TlbHQAS/detail
rudy_v
  • August 13, 2020
yes please - pain to manual config these settings - in a distributed, you only have it once for the first install, the second install should already have it as you specify the system shared
rylanatsafe
Forum|alt.badge.img+14
  • October 28, 2020
These changes will be implemented in FME Server 2021.0 – if you would like to test it out, please use Build 21217 or newer from https://safe.com/downloads. Our 2021.0 documentation will be updated accordingly.
Note: FME Server 2021.0 documentation is available at http://docs.safe.com/fme/2021.0/html/FME_Server_Documentation/Home.htm
