Open
FME Server to store when a workspace was last run
Related products:FME Flow
siennaatsafe
danilo_fme
jdh
warrendev
chriswilson
+6
  • siennaatsafe
    siennaatsafe
  • danilo_fme
    danilo_fme
  • jdh
    jdh
  • warrendev
    warrendev
  • chriswilson
    chriswilson
  • tim_wood
    tim_wood
  • gbj1717
    gbj1717
  • borone
  • davidlee
    davidlee
  • markatsafe
  • DanAtSafe
    DanAtSafe
todd_davis
FME Server records the job information of the jobs that have been run, and usually a system cleanup task will remove these after some time. That's great for what has recently occurred. But in the scenario that you want to find if a workspace has been used over a long period of time, then you would have been required to store this information and long periods of time. So right now, I can't tell and will need to records these details for the foreseeable future.
So I would like a new table in the FME database with an api call in front of it, that records the last date a workspace was run and maybe a couple of other fields such what ran it (e.g. an App, webhook etc) and what user. Over time this could be expanded, so it also said also recorded the last time a Server App was run, or when a token was run (especially as users often create tokens for a range of things and it is very hard for admin to confirm they are used)
todd_davis
Forum|alt.badge.img+22
  • January 31, 2022
This is so people can figure out what is not being used on their FME Server
chriswilson
Forum|alt.badge.img+11
  • February 8, 2022
Don't suppose there's anything useful in JobHistoryStatisticsGathering in the dashboards? I haven't tended to run them. Or could there be.
