Certain characters are not allowed when creating files & folders in the OS. So if you pick data from some source and then use it to create files/folders without any validation, there's a good chance things will fail because of these special characters (see below for an example in Windows). It would be great to have a string function and transformer that will clean up a string to ensure it is compliant with these restrictions (maybe a way to also map to whether certain characters are just removed vs. replaced with a character such as an underscore, etc.). Currently this is doable with a series of nested ReplaceString or ReplaceRegEx functions for example, but not as easy to format each time you need to do this. This function & "cleaner" transformer would simplify such tasks and ensure you have no failures in your translations and data writing tasks.
