Python does not work when called from a SystemCaller on FME Server 2019.2 and 2020.1.2.1
xtian79
I have an environment with FME Server 64 bits 2018.1, and ArcGIS Server 10.7.1
A workspace contains a SystemCaller transformer that is able to run this:
$(PythonEXE) -c "import this".
the parameter PythonEXE is "C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\envs\arcgispro-py3\python.exe"
it works ok.
An update to FME Server 2019.2.3 was made, now the execution of the SystemCaller allways fails:
 Update: Same happens in FME Server 2020.1.2.1 with ArcGIS Server 10.8.1
1Failed to Execute `""C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\envs\arcgispro-py3\python.exe".....
with this:
 `exit_code' has value `-1073740791'
if I run the same command from a CMD it runs OK
if I run the same command from a Powersehll it runs OK
if I run the same command from a CMD with the credentials used by FME Server it runs OK
if I run the same command from a Powersehll with the credentials used by FME Server it runs OK
Is there any configuration or flag that i should activate in order to be able to run ArcGIS Server's python ??
I was able to reproduce the error in a small scale (see the attached workspace).
It is just a workspace calling the zen of python. the same behavior is observed (see file log_job_46.xml - sorry it is txt file, but I had to rename it)
2020-10-06_7-34-21
Best answer by xtian79
The environment/scope created by FME server  to run the calls, does not include a proper configuration for python, so it is required that the system call includes this:
1PATH="C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\envs\arcgispro-py3;%PATH%"
2PYTHONPATH="C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\envs\arcgispro-py3\DLLs;C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\envs\arcgispro-py3\Lib;C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\envs\arcgispro-py3\Lib\site-packages"
3PYTHONHOME="C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\envs\arcgispro-py3\"
at leas t in this case that python from ArcGIS server is used.
virtualcitymatt
Forum|alt.badge.img+45
When you say it runs fine on the CMD are you running it on the same host as the FME Server engine?
After a quick google that ERROR code seems like it could be windows specific?
It's certainly strange that this is failing when run via FME Server.
Is FME Desktop installed on that machine? can you test running it on FME Desktop on the same machine?
xtian79
  • October 6, 2020
Yes, in the same machine. It is an express installation of FME Server
Yes, it could be windows specific, but it happens when python is called from FME SystemCaller
No
I could try to install the FME desktop on the server
virtualcitymatt
No
If you run the process in FME Desktop you should see error messages in the log
In addition there might be more information in the fme engine log on FME Server. Often system calls are logged there, however, it's not always like that.
Anther tip for debugging is to add the console log file on the server. just add ">" and a filepath for a log file output (https://stackoverflow.com/questions/14500616/windows-command-prompt-log-to-a-file)
This might give you some more Information apart from the error code
xtian79
  • October 6, 2020
The attached file log_job_46 is the log from the engine. i took the file from the dark and filthy guts of the server.
virtualcitymatt
Oh sorry i mean this one: fmeprocessmonitorengine.log
xtian79
  • October 6, 2020
Another tip for debugging is to add the console log file on the server. just add ">" and a filepath for a log file output
For this case it is a better redirection to use:
command > file.txt 2>&1
because we require the standard output and the error output.
virtualcitymatt
Nice! sounds good
xtian79
  • October 6, 2020
The output from making the call is:
1Fatal Python error: Py_Initialize: unable to load the file system codec
2ModuleNotFoundError: No module named 'encodings'
3
4Current thread 0x000005a8 (most recent call first):
virtualcitymatt
Hmmm - seems like a path issue. https://stackoverflow.com/questions/42512817/fatal-python-error-on-windows-10-modulenotfounderror-no-module-named-encodings
xtian79
  • October 7, 2020
deanhowell
Forum|alt.badge.img+24
  • November 9, 2022
Hello @xtian79​ where did you set the configuration?
xtian79
  • November 9, 2022
hello @deanhowell​,
What I am going to tell you is not gonna like you, because it will add a layer of complexity but will solve the issue, or at least for me, it did.
I order to use the the system caller I had to create a wrapper that will setup the proper configuration of the  python ESRI's Conda environment, I did it in a PowerShell script:
this file is called Invoke-Python.ps1:
1param
2(
3    [string]
4    $script,
5    [string[]]
6    $arguments
7)
8
9$arcgispro = Get-Item HKLM:\SOFTWARE\ESRI\Server10.9
10$pythonPath = Join-Path $arcgispro.GetValue("PythonCondaRoot") -ChildPath "envs\$($arcgispro.GetValue("PythonCondaEnv"))"
11$python = Join-Path -Path $pythonPath -childpath "python.exe"
12
13$env:PATH = "$pythonPath;$env:path"
14$env:PYTHONPATH="$pythonPath\DLLs;$pythonPath\Lib;$pythonPath\Lib\site-packages"
15$env:PYTHONHOME = $pythonPath
16
17& $python $script $arguments
18return $LASTEXITCODE
In the system caller is used:
1Powershell.exe -c ". """c:\temp\invoke-Python.ps1""" -script """$(PythonScript)""" -arguments """Argument1""","Argument2","""Argument3""","Argument4" "
As you can see there are some arguments with triple quotes those are arguments that include escape characters, i.e. paths with backslash or arguments with quotes.
I hope that this helps you.
deanhowell
  • November 9, 2022
Thanks @xtian79​ I will see what I can do to get it working. ​
