How to change numbers Portuguese Language to normal numerical values
  • Mar 18, 2020 9:02 AM UTC
  • 6 replies
  • 78 views
tomjerry.vl
Cento = 100
Um = 1
Raw DataI wantFme_resultCento Um1011001
How resolve These type of numbers
palhermans
Forum|alt.badge.img+11
  • Mar 18, 2020 10:45 AM UTC
Hi, looks like You are concatenating strings "python wize" ('100' + '1' = '1001') and not make a sum with numbers. So converting to integers might do the trick, i.e like int('100') + int('1') = 101
bruceharold
Forum|alt.badge.img+19
  • Mar 18, 2020 1:04 PM UTC
Not something you get asked every day! Don't forget Portuguese is inflected by gender. Just maybe if you find a list of words you could use NLP processing to do this.
tomjerry.vl
Which transformer are using tell me please
palhermans
  • Mar 19, 2020 7:57 AM UTC
Hi @tomjerry.vl. I did not use any transformer her, just pointing to the fact it seems you are concatenating strings and not making a sum from number/integerss:
Strings: '100' + '1' = '1001'
Numbers, converting strings to integers before s: int('100') + int('1') = 101
If You need to convert strings to integers in FME there is several transformers (or Python for that sake) which can be used as AttributeCreator, AttributeManager. In both cases set up the expression with the Arithmetic Manager.
tomjerry.vl
Tq but my problem is thousands of numbers having test formats in Portuguese language every digit have a different text format like
NumberNumber in EnglishNumber in Portuguese
NumberNumber in EnglishNumber in Portuguese1OneUm
30ThirtyTrinta2TwoDois
40FourtyQuarenta3ThreeTrês
50FiftyCinquenta4FourQuatro
60SixtySessenta5FiveCinco
70SeventySetenta6SixSeis
80EightyOitenta7SevenSete
90NinetyNoventa8EightOito
100One HundredCem9NineNove
200Two HundredsDuzentos10TenDez
300Three HundredsTrezentos11ElevenOnze
400Four HundredsQuatrocentos12TwelveDoze
500Five HundredsQuinhentos13ThirteenTreze
600Six HundredsSeiscentos14FourteenQuatorze
700Seven HundredsSetecentos15FifteenQuinze
800Eight HundredsOitocentos16SixteenDezesseis
900Nine HundredsNovecentos17SeventeenDezessete
1000One ThousandMil18EighteenDezoito
19NineteenDezenove
197One Hundred and Ninety-SevenCento e Noventa e Sete20TwentyVinte
367Three Hundreds and Sisty-SevenTrezentos e Sessenta e Sete21Twenty-oneVinte e Um
1453One Thousand Four Hundred and Fifty-ThreeMil e Quatrocentos e Cinquenta e Três.........
555Five Hundreds and Fifty-FiveQuinhentos e Cinquenta e Cinco
Given Raw source Test format but i need numerical format in fme how to convert text format to numerical format please tell me
note: Between numbers 1-1999
For example : Rua Cento e Um Rodovia converted to Rua 101 Rodoiva
jovitaatsafe
Hi @tomjerry.vl,
I don't have a full answer for you but this previous question may be a good place to start as there are a lot of solutions offered by the Community. Some of the suggestions included the use of python modules for going from words to numbers. I believe something like num2words supports Brazilian Portuguese if that's something you might like to explore. Or if you wanted to create your own solution, ebygomm's workspace template may be a good place to start, but I definitely see your problem with the tens/hundreds being a bit more difficult to handle than in English. Hope this offers some more options to try!
