FME server data download sending empty emails
  • Dec 8, 2015 6:48 PM UTC
  • 60 views
We are using FME Server 2015. It's installed since a couple of days.
TOday, we noticed that some of our datadownload services are sending empty emails (async). Others are sending the emails as configured.
Any idea of why we meet that behaviour?
Regards.
Vincent.
mark2atsafe
Forum|alt.badge.img+59
Are you using notifications to send the email? If so, are the failing emails using the same topic/subscriber as the successful ones? Also, are the jobs sending empty emails failing in some way? Perhaps they are reading/writing zero features? I'd start by looking at some of these questions, check the job logs to see what has happened. I'm sure there must also be a log somewhere of the notification service (though I don't know where).
Hi Mark,
the emails are using the same topic/subscribers as the successful ones.
I just tested one thing now: in the writer, there is a fanout activated. when I disable the fanout, the email is correctly filled in....
Is there anything "special" to mention when using a fanout on DGN?
Regards.
Vincent.
fmelizard
Forum|alt.badge.img+22
  • Dec 28, 2015 11:01 PM UTC
Hi Mark,
Regards.
Vincent.
If you are using dataset fanout with data download then there are some additional configurations required. Please see the following article:
https://knowledge.safe.com/articles/332/dataset-fanout-doesnt-work-for-services.html
Also note that for FME Server 2016.0, this configuration is no longer required.
fmelizard
Also note that for FME Server 2016.0, this configuration is no longer required for the workflow to be successful.
