FME Desktop 2020: How to disable writing (duplicating) the result of workbench at each run?
jamal
Forum|alt.badge.img+5
I couldn’t figure out how to disable writing the result of workbench as each run. I observed that the output is duplicated in the esri file geodatabase at each run
Best answer by david_r
On the output feature type, set the table operation either to "Drop and create" or "Truncate existing".
Example:
This only affects a specific feature class.
Alternatively you can force FME to overwrite any previously existing file geodatabase at each execution:
  • April 29, 2020
Example:
jamal
  • April 29, 2020
Many thanks david_r for the help. It works fine
Best
Jamal
