Why don't I see "power" attribute from a GPX file?
ronmak
It's been a while since I posted but I am doing something different and after spending some time looking in the forums for a solution, I thought I would just post it.  It's probably something simple, but I have limited experience with FME.
I downloaded a GPX file from my bike computer and want to do some data processing on it, but when I view the file in FME Inspector, I am missing the "power" attribute which appears in the GPS as shown below.
   <trkpt lat="43.7513380" lon="-80.5606200">
    <ele>335.6</ele>
    <time>2023-01-07T13:02:24Z</time>
    <extensions>
     <power>36</power>
     <gpxtpx:TrackPointExtension>
      <gpxtpx:atemp>20</gpxtpx:atemp>
      <gpxtpx:hr>89</gpxtpx:hr>
      <gpxtpx:cad>51</gpxtpx:cad>
     </gpxtpx:TrackPointExtension>
    </extensions>
   </trkpt>
I do get the time, temperature, hr and cad, but not <power>.
I expect it has something to with the fact that it is not in the <gpxtpx> section, but then neither is time or elevation, but I see them in FME.  How do I expose <power>?
Best answer by dustin
Use the XML reader instead of the GPX reader. You will need to set the Elements to Match parameter to the trkpt element.
danilo_fme
Forum|alt.badge.img+43
  • January 7, 2023
Hello @ronmak​
Please, could you share your data?
ronmak
  • January 8, 2023
danilo_fme wrote:
Hello @ronmak​
Here is the data. Don't get too hung up on the spatial data. It is from a bike computer on a trainer that wasnt really going anywhere!
nielsgerrits
Forum|alt.badge.img+54
I do not have an answer, but as it is XML, it is not too hard do it yourself. XMLFragmenter to get the trackpoints using gpx/trk/trkseg/trkpt as elements to match, enable flattening and you're done.
dustin
Forum|alt.badge.img+30
  • January 9, 2023
danilo_fme
  • January 9, 2023
Great solution. Congratulations!
ronmak
  • January 10, 2023
resulting chartThanks! It works great.
