Which method to find the layers name that has completely no data inside?
  • May 12, 2023 2:50 AM UTC
  • 85 views
spiderman
Forum|alt.badge.img+7
Hello ,
is there a way to find the layers name that has only attribute names but all attributes name has completely no data inside it
source data :oracle non spatial
FME 2021
Thanks in advance
Best answer by david_r
My preferred method would be as follows:
  • Use a FeatureReader in "Schema Only"-mode to get a list of all the table names.
  • Use a SQLExecutor to retrieve the number of records for each table, e.g.
select count(1) as MY_TABLE_COUNT
from @Value(fme_feature_type_name)
  • Use a Tester to check if MY_TABLE_COUNT= 0
 This will avoid reading any data into FME, which is very efficient especially if there are tables with a lot of data among the empty ones.
  • May 12, 2023 6:37 AM UTC
  • May 15, 2023 9:47 AM UTC
You'll find it on the schema feature, it's not necessary to expose it manually (note that the name is lower case):
imageMake sure to configure the FeatureReader to only read the schema features, and not to include the table contents:
spiderman
  • May 15, 2023 4:39 PM UTC
Thanks a lot
