Unable to store connection
markcoopersdc
Hi
I am currently trying to create a web connection in FME desktop but it says the following:
Unable to store connection. Please try again
SQL Query INSERT INTO fme_nc_namedconnections (connectionname, username, servicename, connectiontype) VALUES (?, ?, ?, ?) failed. Error: attempt to write a readonly database
This happens with any connection type I try with this particular windows user account. If I log in with a different account, I am able to save the connection, but I no longer use that account and need to run it through this one.
Does anyone know how to resolve this please?
Thanks
  • May 12, 2023
Sounds like a permissions issue on the file containing the named connections.
markcoopersdc
  • May 12, 2023
I think you are right. Don't suppose you know how to fix that?
Forum|alt.badge.img+44
  • May 12, 2023
Have you checked what the Default Paths are set to in options?
  • May 12, 2023
Depends on your OS and your network configuration, as well as what you're allowed to do (your own permissions). I suspect the best solution would be to talk to your IT support people.
markcoopersdc
  • May 18, 2023
Is it the fme_privatekey.jceks file that it is saved to? If so, this user has full control of the file according to explorer
dnaumov
Forum|alt.badge.img+10
  • July 14, 2025
Try starting FME Form as an Administrator
