I'm trying to output CSV files to Word or PDF. Formatting issues... not sure which transformers to use and what settings to use... Thank you in advance!!!
Hi @shawn.brandt ,
The MSWordStyler will likely come in handy here before connecting to the writer/FeatureWriter. When it comes to PDF, there is also an FME Hub Transformer called the TableAdder which can be used to generate the text/outline features in a table format. This can be used in tandem with the PDFStyler and PDFPageFormatter to style the font/color/etc. and position it on the page.
Depending on what you are putting into the table, the MSWordStyler might be easier to work with as the word document will wrap the text for you (more flexible). With PDF, you have to do all of the formatting (i.e. text wrapping) before creating the text feature with the TableAdder.
OK... I believe I have the MSWordStyler... and I think I am using it properly....
I understand the "stretch" or using "inches/CM" and how to put in a number value...
I believe I am using the MSWordTableAdder....
Should I be using TableAdder or MSWordTableAdder???
My next question comes with the FeatureWriter...
If I'm wanting to have the font size to be 10... I'm not understanding how to modify that, or other parts of the table. When I write the table to MSWord... it only opens up a "letter" (8.5x11) in "portrait" with "normal margins"... I was needing a "tabloid" (11x17) in "landscape" with "narrow margins".
Hi @shawn.brandt ,
Here is a very rough example of a PDF table output vs a word table output with the attached workspace: You can make much nicer-looking PDF's (like this demo) than what I attached above but just to give you an idea.
Hi @shawn.brandt ,
Correct you should be using the MSWordStyler if you are writing to a Word file. If you are writing to a PDF, then you'll need to use the TableAdder!
For font size, this can be set in the MSWordStyler:
For Column Width (admittedly I haven't used this yet so I am pasting some documentation in hopes it clarifies it as it depends on the units you setting in the transformer. This is percentage as an example): "Any positive number is valid here, or the word Stretch. Columns with the width Stretch will all share any leftover space after columns with specified sizes are given their space.
If Percentage of Page Width was chosen for Width Units, then 100 means the entire page width, while 1 means only one percent.
Format attribute set: msword_table_col_width"
Lastly for the margins/page format. This is a great question and it should be handled by using a template file in the FeatureWriter parameters (this screenshot shows a writer but it's the same in the FeatureWriter). You'll first need to save a template file in MS word with the margins you want and set that as your base Microsoft Word File.
INCREDIBLE... I knew this was just below the surface for me....
Am I missing something??? I don't see the same font options as you showed in your screen shot.
Ah! Might be a difference of versions. I'm using 2021.2 fwiw but you should still be able to set it by exposing the msword_font_size format attribute and setting the value there. Or if you wanted to try it out in 2021.2 feel free to download it and see it in action ;P
You can expose it in an AttributeExposer and set the font size value in an AttributeManger (or equivalent). The new parameter in the MSWordStyler does just that but makes it a bit more streamlined.
Hi @shawn.brandt ,
Hi @shawn.brandt ,
Hi @shawn.brandt ,
24 votes
14 votes
9 votes
8 votes
6 votes
6 votes
6 votes
6 votes
5 votes
5 votes
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
OKSorry, our virus scanner detected that this file isn't safe to download.
OKWe use cookies to enhance and personalize your experience. If you accept you agree to our full cookie policy. Learn more about our cookies.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
