StringReplacer to find last space
  • Aug 26, 2020 8:37 PM UTC
  • 161 views
dos_gis
Forum|alt.badge.img+3
Hi, Regex help please. I'm trying to replace the last space character in a list of names with a comma. Some of the names have multiple spaces in them:
Example:
John Doe
John Charles Doe
John Jimmy Charles Doe
The result I'm looking for:
John,Doe
John Charles,Doe
John Jimmy Charles,Doe
Thanks!
Best answer by davtorgh
I think you can set parameter 'Text To Replace' to
\s+(\w+)$
and 'Replacement Text' to
,\1
If you suspect there may be trailing spaces, add `\s+` before `$`.
Hope that helps!
davtorgh
Forum|alt.badge.img+12
  • Aug 26, 2020 9:18 PM UTC
\s+(\w+)$
,\1
Hope that helps!
dos_gis
  • Aug 26, 2020 9:24 PM UTC
Works perfectly! Thank you.
I didn't realize that you could add the \\1 qualifier to the replacement text.
mark2atsafe
Forum|alt.badge.img+59
\s+(\w+)$
,\1
Hope that helps!
Interesting. There's a LastSectionOfStringRemover on the Hub that does this, but removes everything after that character. I should update it to also do a replacement, using this piece of regex. Thanks for posting a great answer.
