SDE Writer error after reading image
  • Aug 16, 2022 5:53 PM UTC
  • 77 views
kschultz
Participant
I've encountered this error a few times and can't figure out what exactly is going on.
2022-08-16 08:34:06| 51.4| 0.0|ERROR |Esri Geodatabase Writer: Feature Type Definition 'Output' was requested, but not defined. Please visit https://www.safe.com/support
2022-08-16 08:34:06| 51.4| 0.0|ERROR |BADNEWS: GEODATABASE_SDE writer: A fatal er
I have an SDE writer after a reader that is reading a PNG. From what I understand it might do with the fme_feature_type being a PNGRaster but if i change or remove it I get the same error.
evieatsafe
Forum|alt.badge.img+28
  • Aug 19, 2022 1:00 AM UTC
Hi @kschultz​ thanks for your post! Do you think you could provide a sample dataset or workspace for us to replicate the issue? If this is impacting you and your work then I would suggest opening up a case for a deeper look into the issue: https://community.safe.com/s/submit-case
j.botterill
Forum|alt.badge.img+69
  • Aug 23, 2022 1:00 PM UTC
Are you writing a raster dataset for the SDE writer ? Sounds like it’s not defined, as to the type of object on the writer
