Results from FeatureJoiner changing number format
  • Oct 21, 2021 2:27 PM UTC
  • 46 views
I have selected ~50 records from a shapefile of ~5.5 million records using a column of unique reference numbers. The unique reference numbers are stored in a CSV. I have used FeatureJoiner to join the CSV and shapefile.
The resulting joined records have been correctly selected but the values in final two columns containing the X and Y coordinates have been altered when viewed in the visual preview.
Where in the workspace has the change taken place?
caracadrian
Forum|alt.badge.img+23
  • Oct 21, 2021 2:50 PM UTC
Can you provide some sample data and a sample workspace?
f.kemminje
Forum|alt.badge.img+11
  • Oct 22, 2021 6:10 AM UTC
write to CSV and check, keep precision for decimal. Sometimes visual previews may show like this.
or you can change the field to text type, in the CSV file.
