Reduce duplicates, keeping uniques only
  • September 26, 2022
  • 9 views
scarter
Forum|alt.badge.img+10
I have a table containing ten lines (each one a street). Each street has a name and a zone value. But there are some duplicate records…
Street_name                       Zone_name
St James Street                  Zone B
High Street                         Zone B
High Street                         Zone B
High Street                         Zone D
High Street                         Zone D
Acacia Avenue                   Zone B
Acacia Avenue                   Zone C
How would I reduce these down to unique records only. So, I’d end up with this…
High Street                         Zone B
High Street                         Zone D
Thanks,
Best answer by david_r
You can also consider the DuplicateFilter, set both Street_name and Zone_name as key attributes.
Forum|alt.badge.img+58
You could use a Sampler, set it to group by both attributes and then pass through only the first feature.
scarter
Thanks for that, David_R. It done the job. Regards, Stuart
