PointOnAreaOverlayer not working
  • Mar 31, 2022 12:16 PM UTC
  • 6 replies
  • 249 views
benvk
Forum|alt.badge.img+8
I have a basic workbench where I have points stored in an ESRI ArcGIS Online Point Feature Layer, and I have an ESRI Enterprise SDE Polygon Feature Class. 99% of my AGOL points fall within a SDE polygon.
I have created a simple workbench with two readers (AGOL and SDE as previously described), as my screenshot shows, the points fall within the polygon areas, but the tool is not returning a single overlap whereby a point sits on a polygon, yet the screenshot clearly shows the point within the polygon. See '_overlaps' column in screenshot are all 0
Is there something basic I am missing? I just want each point to have an attribute outlining the polygon it is within.
2022-03-31 23_11_03-Window
Best answer by redgeographics
Are you sure both datasets are in the same coordinate system? Only then will the PointOnAreaOverlayer overlay them properly (the fact that the Visual Preview shows them as overlapping does not mean they're in the same coordsys)
Forum|alt.badge.img+63
benvk
  • Mar 31, 2022 12:29 PM UTC
That's a good point, the ArcGIS online stuff would have been captured using the ESRI international collector app, but our SDE road segments are stored in local Australian MGA zone 55. I must be able to reproject them to be the same.
I must admit that the ​visual preview made me think they were already overlapping!! That's a trap for new players!
It certainly is. When you spatially combine two or more streams of data in FME, e.g. by doing an overlay, FME is going to assume all the coordinates are in the same "space", so it's up to you as the workspace author to make sure they are.
benvk
  • Mar 31, 2022 12:40 PM UTC
What is the most efficient way for me to define both input datasets​, so they can be compared with the overlapper?
You can use a Reprojector (or ESRIReprojector) to reproject one of the datasets to the coordinate system of the other. To find out what they are you can check the feature caches of the input data, if you select a single feature and check the Feature Information panel you'll see which one it is.
benvk
  • Mar 31, 2022 11:14 PM UTC
Fantastic, its working perfectly now, thanks for your help.
