Make an analyse of DynamoDB from FME
  • Jul 22, 2020 12:40 PM UTC
  • 71 views
geo-x
Dear FME community.
I've DynamoDB DataBase. In this DB, directly in AWS I can make a request (for example I can select only data between two dates) :
It's necessary for don't scan all the table.
In FME I can see the equivalent of the classical query in DynamoDB base on the index :
Like
The problem is, in this case, I must choose one value before to choose an other filter.
Do you know how can I make a filter lika the "analyser" in FME ?
Thanks.
  • Jul 22, 2020 12:46 PM UTC
I've never tested this myself, but according to the documentation it should be possible to use the "Between" operator (opérateur de triage) rather than < and >. Would that be a possibility?
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/dynamodb/dynamodb_reader.htm
geo-x
  • Jul 22, 2020 3:11 PM UTC
Hi @david_r and thanks for your reply.
In this case, yes it is possible to use the "Between" operator but we must to have a unique key before (the partition key).
