I would like a total count for how many times each record appears in the dataset.
  • October 21, 2020
  • 199 views
cshir065
Hello,
I would like to total the number of times each record appears in the dataset. Here is an example of what I would like to count:
FMEquestion1I've tried using the FieldCalculator but I just keep getting 0's for the sum function. See photo below:
FMEquestion2I'm not sure how to set the parameters in the FieldCalculator to perform this function. Here is what I have currently set:
FMEquestion3Thank you!
Best answer by alexist
You could try using the Total Count in the Statistic Calculator grouping by your attribute.
  • October 21, 2020
Forum|alt.badge.img+43
  • October 21, 2020
You just need to add the LocationID attribute as the GroupBy here
Capture
cshir065
  • October 21, 2020
Capture
@ebygomm​  and @alexist​  Thank you that gave me the count!
