I need to use a form of testing based on the outcomes of another transformer
  • Feb 9, 2021 9:09 AM UTC
  • 74 views
The image in the annex shows my workbench.
This is the result that can be seen in ‘Passed from Tester_2’:
NAME ; DBK
Organisation X1 ; 111
Organisation X2 ; 222
This is the result that can be seen in ‘SQLCreator_3’:
ID ; OWNER_ORG ; CLIENT_ORG ; MONITOR_ORG
1 ; 111 ; 111 ; 333
2 ; 222 ; 222 ; 222
3 ; 333 ; 444 ; 555
4 ; 333 ; 222 ; 333
5 ; 444 ; 555 ; 111
I would like to use a transformer that uses the results from ‘Passed from Tester_2’ to check if one of these DBK values is present in the organisation columns of result ‘SQLCreator_3’.
So I need the transformer to select ID 1, 2, 4 and 5. But not 3 as Organisation X1 and X2 is not present in one of the three organisation columns.
Can anyone explain to me how I can do this?
Thanks in advance!
Best answer by chrisatsafe
Hi @eva218​ ,
I tend to handle this by concatenating the list of test conditions into a single attribute, merging the datasets, then using an IN operation in the Tester. There's likely a few different ways to handle this but this is my go-to for this task.
2021-02-09_10-38-56I've attached the example from the screenshot above. Hope that helps.
chrisatsafe
  • Feb 9, 2021 6:44 PM UTC
Hi @eva218​ ,
hkingsbury
Forum|alt.badge.img+73
  • Feb 9, 2021 7:04 PM UTC
I'd suggest using the SQL Executer. However my SQL isn't great so i'm struggling to think of the statement to achieve this.
Maybe @david_r​  or @ebygomm​  will be able to help a bit more
  • Feb 11, 2021 3:50 PM UTC
Hi @eva218​ ,
Thanks @chrisatsafe this indeed does the job! 😄
chrisatsafe
Awesome, thanks for letting me know you got it working!
