I have two text files that each are in a zip file, which are then in another Zip file.
  • Feb 24, 2023 5:41 AM UTC
  • 11 replies
  • 110 views
tcronin
Forum|alt.badge.img+4
Structure is
*.zip\\
text1.zip\\
File.txt
text2.zip\\
File2.txt
tcronin
  • Feb 24, 2023 6:43 AM UTC
I can handle the txt in the zip files, that is pretty easy. I tried *.zip\\*.zip, *.zip\\*.*, *.zip\\**\\*.txt, etc, basically everything I could find in the doc.
Forum|alt.badge.img+63
So what's your question?
tcronin
  • Feb 24, 2023 7:39 AM UTC
How do I extract two txt files that live in zip files that then live in 1 zip file?
hkingsbury
Forum|alt.badge.img+73
  • Feb 26, 2023 7:17 PM UTC
You can use the wildcard "*" in the reader like so :
C:\\Users\\hamish\\Downloads\\*.zip\\**\\*.txt
imageFME treats zips just like folders
tcronin
  • Feb 27, 2023 9:53 PM UTC
So I tried
tcronin
  • Feb 27, 2023 9:57 PM UTC
It does seem to work with a Text file reader.
tcronin
  • Feb 27, 2023 9:58 PM UTC
In the sense that it adds to the canvas, but still fails to run
hkingsbury
  • Feb 27, 2023 10:29 PM UTC
So I tried
Whats the error in the log?
The reader you're using is a csv reader, but the file extension you've specified is txt. Is that file actually a csv?
tcronin
  • Feb 27, 2023 10:55 PM UTC
That is correct. I have tried CSV which flags the error directly. If I try and use text file, i get... 2023-02-27 14:55:12|  0.1| 0.0|ERROR |Text File Reader: Source dataset 'C:\\Users\\tcronin\\AppData\\Local\\Temp\\wbrun_1677533700583_22080\\fmetmp_21\\TempFS_1677538512093_35028\\dsTEXTLINE_1_0\\efs_files_20230207110823.zip_0\\**\\*.txt' does not exist
evieatsafe
Forum|alt.badge.img+28
  • Mar 2, 2023 10:45 PM UTC
Hi @tcronin​ if you are able to add the text file reader to the canvas, what is the error you get when trying to run the translation? Could you provide the translation log file as well as the text file or csv you are trying to read? If you are still experiencing issues you may want to submit a support case with us so that we can investigate further. Happy to help :)
tcronin
  • Mar 14, 2023 9:51 PM UTC
I will go through Support, as the data is sensitive.
