I have a set of points to trace a route, but there were failures in the tracing and the trace is clearly not correct. Is there a way to create lines from points by setting a starting point and having the line created from there to the closest point?
  • Aug 17, 2022 9:11 AM UTC
  • 73 views
In print it is possible to visualize the line created, totally without logic, and in red what would be the appropriate route.
TESTE FME
Best answer by geomancer
In this question there is mention of an algorithm to sort points in a clockwise order relative to a central point. It looks like that algorithm could work for this route (although unfortunately it was not suited for the data from the original question).
geomancer
Forum|alt.badge.img+71
  • Aug 17, 2022 12:18 PM UTC
  • Aug 17, 2022 12:42 PM UTC
Thanks for the support.
