I cannot make a geotif without jpeg compression
  • Feb 3, 2021 11:40 AM UTC
  • 264 views
koenvdw
Forum|alt.badge.img+7
Hi
I have a lot of small geotif tiles. I need to mosaic them together as geotif in specific zones.
I tried the standard compression which is jpeg. The problem is that some zones are to large for the compression method.
I get this error:
"GEOTIFF writer: Failed to write the output file using JPEG compression. The raster is being written with a tile size of '29005' rows by '82874' columns, whereas the maximum number of rows or columns that JPEG compression can handle is 65500. Please reduce the tile size if writing a tiled file, or reduce the size of the raster"
So I'm thinking I only need to change the compression method.
I tried all the other compression methods and I always get the same warning:
"GEOTIFF writer: Existing value for creation option 'INTERLEAVE' was 'BAND'. Overwriting with the new value 'PIXEL'
GEOTIFF writer: Existing value for creation option 'COMPRESS' was 'NONE'. Overwriting with the new value 'JPEG'"
Followed with the same error mentioned above.
So I'm clearly doing something wrong as I would be very supprised that FME makes all the other options available if they wouldn't work.
Is there a workaround?
Best answer by daveatsafe
Hi @koenvdw​ ,
There might be format attributes from the source GeoTIFF files that are overriding the settings on the writer. Please use a BulkAttributeRemover transformer to remove any attributes starting with 'geotiff_'
daveatsafe
Forum|alt.badge.img+24
  • Mar 11, 2021 7:11 PM UTC
Hi @koenvdw​ ,
koenvdw
  • Oct 5, 2021 9:34 AM UTC
Sorry for the long wait, but this works great.
