I am getting errors while JobHistoryReader
  • September 28, 2022
  • 5 replies
  • 57 views
Forum|alt.badge.img+5
Feature Type: `JobHistoryReader_LoopHere'
Attribute(32 bit integer): `Loop to JobHistoryReader_LoopHere1664443291 Input Splitter.BranchingFactory.Count' has value `1'
Attribute(string: UTF-8) : `_min_job_age' has value `20220928000000'
Attribute(64 bit integer): `_offset' has value `0'
Attribute(string: UTF-8) : `fme_feature_type' has value `Creator'
Attribute(string: UTF-8) : `fme_geometry' has value `fme_undefined'
Attribute(string: UTF-8) : `fme_type' has value `fme_no_geom'
Coordinate System: `'
Geometry Type: IFMENull
Coordinate Dimension: 2
Loop to JobHistoryReader_LoopHere1664443291 Input Splitter (BranchingFactory): Transformer/Factory JobHistoryReader_HTTPCaller is blocking and cannot be used in a loop, but was found between 'Loop to JobHistoryReader_LoopHere1664443291 Input Splitter' and 'JobHistoryReader_LoopHere1664443291 Input Splitter'
An error has occurred. Check the logfile above for details
  • September 29, 2022
anyone
keziaatsafe
Forum|alt.badge.img+7
  • October 3, 2022
Hi @asadamjad​ ,
A couple of questions to get started:
  • Are you running this workspace on FME Server?
  • Do you have a job log for us to look at?
  • What version of FME Server are you using?
Thanks,
Kezia
mferwerda3
  • September 26, 2024
Any updates on this ?
I am now getting this same error, in both Desktop and Server.  It worked fine until 3 days ago, the workspace was not edited.
FME 2022 Build 22765
2024-9-26 09:44:52 | +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
89           2024-9-26 09:44:52 | Feature Type: `JobHistoryReader_LoopHere'
90           2024-9-26 09:44:52 | Attribute(32 bit integer): `Loop to JobHistoryReader_LoopHere1709132937 Input Splitter.BranchingFactory.Count' has value `1'
91           2024-9-26 09:44:52 | Attribute(string: UTF-8) : `_min_job_age' has value `20240925000000'
92           2024-9-26 09:44:52 | Attribute(64 bit integer): `_offset' has value `0'
93           2024-9-26 09:44:52 | Attribute(string: UTF-8) : `fme_feature_type' has value `Creator'
94           2024-9-26 09:44:52 | Attribute(string: UTF-8) : `fme_geometry' has value `fme_undefined'
95           2024-9-26 09:44:52 | Attribute(string: UTF-8) : `fme_type' has value `fme_no_geom'
96           2024-9-26 09:44:52 | Coordinate System: `'
97           2024-9-26 09:44:52 | Geometry Type: IFMENull
98           2024-9-26 09:44:52 | Coordinate Dimension: 2
99           2024-9-26 09:44:52 | ===========================================================================
100        2024-9-26 09:44:52 | Loop to JobHistoryReader_LoopHere1709132937 Input Splitter (BranchingFactory): Transformer/Factory JobHistoryReader_HTTPCaller is blocking and cannot be used in a loop, but was found between 'Loop to JobHistoryReader_LoopHere1709132937 Input Splitter' and 'JobHistoryReader_LoopHere1709132937 Input Splitter'
crystalatsafe
Forum|alt.badge.img+18
Hi @mferwerda3
I found this community post: Dasbhoard workspace JobHistoryStatisticsGathering.fmw Errors after upgrade to FME Server 2022.2.7.
It looks like the solution for that error is to change the maximum number of concurrent HTTP Requests from 25 back to 1.
Please let me know if this works for you, and if it doesn't, I would be happy to look into this further.
Crystal
mferwerda3
  • October 8, 2024
Thanks, that worked, much appreciated.
