Archived
Add NullAttributeMapper functionality in AttributeManager
Related products:FME Form
erik_jan
The "Set Default Value" option in the AttributeManager only works for new attributes.
That forces me to use a NullAttributeMapper for each different default value (multiple attributes).
Adding this to the AttributeManager (Set a default value for Null and Empty attributes) would reduce the number of transformers in my workspace.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
erik_jan
Forum|alt.badge.img+18
  • December 15, 2016
Just found out that this can be done in the AttributeManager using conditional values at the Set Value option ( If attributes not has a value, set to new value).
erik_jan
  • December 15, 2016
But the ability to set the default value for existing attributes without a value would save time setting up the conditional values.
