HTTP/FTP transfer error: 'Failure when receiving data from the peer'
  • Oct 5, 2020 10:52 PM UTC
  • 882 views
Hello!
I´m running a workspace that uses a HTTPCaller but this error is shown "HTTP/FTP transfer error: 'Failure when receiving data from the peer'" and translation fails....do you know how to solve this error? Thanks in advanced. The data is from an external website.
  • Oct 6, 2020 9:05 AM UTC
Could it be a timeout issue? Perhaps try increasing the two timeouts in the HTTPCaller, look under the section HTTP Client Options.
itsmatt
Forum|alt.badge.img+48
  • Oct 6, 2020 9:40 AM UTC
You miiight also get a little more information from the log if you turn on DEBUG logging in the options. Note: This is only recommended for web based debugging. Ignore everything else including BADNEWS. BADNEWS is fine.
Once you have figured out the issue then turn debug logging back off
  • Oct 6, 2020 10:00 AM UTC
Agree completely about using debug mode here.
On a side note, I'd love to have a chat with the poor soul that decided that printing "BADNEWS" for non-critical debug messages was a good idea ;-) I can't count the number of clients I've had to assure that no, it's not really bad news for your translation!
