How to use the NDVI calculator
  • Feb 26, 2021 3:46 PM UTC
  • 84 views
koenvdw
Forum|alt.badge.img+7
Hi
I have a near infrared jpg.
In the data inspector it says Band 0 (GRAY8).
When I look at the NDVI calculator I see two ports (Red, Infrared).
I've seen somebody used something like this:
1
I don't know how to configure the testfilters so they give the correct output.
Can somebody tell me if that's the way to go and if so how to configure the testfilters?
hkingsbury
Forum|alt.badge.img+73
  • Feb 28, 2021 10:28 PM UTC
Is your JPEG only one band? NDVI calculations are usually done using multi spectral imagery. This images will included RGB and a range of other bands. the NDVI calculation requires the visible red spectrum as well as the near infrared spectrum
kailinatsafe
Forum|alt.badge.img+24
Hello @koenvdw​ ,
try adding a RasterBandPropertyExtractor before your Testfilter to get your raster feature information! Should be able to find band name or definition there.
Let me know if you have any success,
Kailin Opaleychuk.
