How to use FME to find mean & standard deviation?
  • October 20, 2019
  • 5 replies
  • 116 views
dataninja
Alteryx has a tool called smart tile and I am having trouble replicating it in FME.
https://help.alteryx.com/2018.2/Tile.htm
Can anyone give me some advice on how to replicate the tool in FME?
  • October 21, 2019
Hi, you may try to use "Tiler" transformer in FME, but you would also need to make the feature containing specific values beforehand.
dataninja
  • October 21, 2019
Do you know how I can replicate the smart tile feature?
debbiatsafe
Forum|alt.badge.img+20
  • October 25, 2019
Not personally familiar with this tool. But based on the Alteryx documentation, I would recommend trying to use the StatisticsCalculator to find the mean and standard deviation. To find the tile number, try an AttributeCreator with conditional values set up based on whether the value is within 1 standard deviation of the mean. This is a similar Q&A post.
Example workspace: assignvaluebasedonstandarddeviation.fmw
fmelizard
Forum|alt.badge.img+19
  • October 25, 2019
Just because it looked fun, I added to Debbie's solution by using a ValueMapper to assign even more categories ("tiles") after doing a bit of calculation in an ExpressionEvaluator. As always, many paths to success here .. smarttiler.fmw
dataninja
  • October 25, 2019
This is great! Thanks so much for your help!
