How to update an existing field?
  • Sep 21, 2021 10:38 PM UTC
  • 610 views
messagemauri
I have an existing ArcSDE table with several fields but there is one field called 'state' that has no value. I want to assign the value 'NY' to this field with no conditions, so all records should have the field 'state' with a value 'NY'. I can do this in ArcMap or using SQL, but when I try it with FME using the Feature Writer it does not update anything to that field.
I have an Attribute Manager that sets the value 'NY' to the state field, I then connect it to the FeatureWriter
Feature Operation: Update
Table Handling: Use Existing
Update Spatial Column: No
Row Selection:
Columns: state
FME Desktop 2019
fme_0921
Thank you.
ciarab
Forum|alt.badge.img+10
  • Sep 22, 2021 12:42 AM UTC
That column selection is to indicate an identifier of which row to update ​.
The columns specified in the corresponding column picker dialog will be used for matching destination rows. All matching rows will be selected for update or delete
So as you have set it, you are searching for matching values in the state field to update those records and none currently match. You need to set it to a unique id and it will match that id and then update all the specified fields in the writer . If you only want to update state then remove all the other attributes .
Thats one way to do it anyway hope that helps
