You can use a Directory and Filepathnames reader. Then sort the data on path_modified_date.
Then use the Sampler to get the latest modification.
I wanted the modified date of the Personal Geodatabase I'm reading a Feature Class from so I used your suggestion but with a Path Filter of the PGDB file name rather than the Sampler. Now I'm just working on making that date an attribute of all the features in the Feature Class...
Update: figured out a way:
I use the Counter on the Feature Class data to create values (_count) that will match the Cloner output (_copynum). These are the join fields in FeatureJoiner_4.
Both AttributeCreators create an attribute called _join_id with a value of 1 so the date modified will be merged with the Summary feature from the StatisticsCalculator (thanks to
https://knowledge.safe.com/questions/5293/how-to-count-the-number-of-features-with-the-same.html).
Cloner uses the Total Count from StatisticsCalculator to create the required number of copies.
