How to remove many blank spaces in a field so only one blank space remains?
Dear FME community,
I have an attribute which has many blank spaces in the middle. I want to reduce the amount of blank spaces to only one single space (character). I'm not very fit in regular expression, so I'm hoping somebody can tell me the code for the StringReplacer. Many thanks!
Kind regards
Thomas
erik_jan
Forum|alt.badge.img+22
  • March 30, 2016
I managed to do this using a sequence of 2 StringReplacer transformers:
The first using regular expressions replacing \\s* by #, the second not using regular expressions replacing ## by a white space.
Hi @thomask
one more option is a single StringReplacer with regular expression. The StringReplacer parameters should be:
  • Text to Match: [<space>]+
  • Replacement Text: <space>
  • Use Regular Expressions: yes
deanhowell
Forum|alt.badge.img+24
  • May 17, 2019
Just a slight update based on FME 2019
