How to filter the last returned row
oliver.morris
Forum|alt.badge.img+13
I am essentially looping through httpcaller results and need a way to pass a value from the last record returned in a loop, I dont know how many records will be returned. I was using the stats calc to get the max value but that is blocking the loop from running within the one workbench. Does anyone have any suggestions, thank you
Best answer by jdh
To use blocking transformers in a loop, you need to have a linked rather than embedded custom transformer. The loop input will also have to be published (really annoying, I generally call it LoopInputDoNotUse)
oliver.morris
  • July 16, 2021
hkingsbury
Forum|alt.badge.img+61
  • July 18, 2021
oliver.morris wrote:
Use the sampler with it set to "Last N Features"
oliver.morris
  • July 19, 2021
thanks but unfortunately I get - Input Splitter (BranchingFactory): Transformer/Factory GetMembers_Sampler is blocking and cannot be used in a loop, but was found between... so the sampler is a blocking transformer for this loop as well.
jdh
Forum|alt.badge.img+36
  • July 19, 2021
oliver.morris
  • July 20, 2021
thanks, I went down this route as I dont think it is possible without blocking transformers.
